--- title: "Ignite connection guide" slug: "ignite-connection-guide" description: "Connect your Ignite data to Supermetrics with our guide. Learn about permissions, query types, and step-by-step connection instructions." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/ignite-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Ignite connection guide This guide contains all permissions and requirements for connecting your Ignite data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/ignite-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Ignite account, you need a client ID and client secret from your contact person at [RealEstate.com.au](https://www.realestate.com.au/). ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Campaigns**: Measure the performance of your property campaigns. - **Campaign creatives**: Retrieve a collection of flight data for a specified campaign ID, including a daily breakdown of performance metrics. - **Campaign flights**: Retrieve a collection of creative data for a specified campaign ID, including a daily breakdown of performance metrics. - **Aggregated project profile performance report**: Retrieve total project performance reports for property advertising campaigns. - **Daily project profile performance report**: Retrieve daily project performance reports for property advertising campaigns. ## Connection instructions When connecting to Ignite, you need your client ID and client secret. 1. Select the Ignite data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your client ID and client secret. 3. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select a query type to use, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Ignite from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
