--- title: "HubSpot Contacts connection guide" slug: "hubspot-contacts-connection-guide" description: "Learn how to connect your HubSpot Contacts data to Supermetrics and start sending data to your reporting tools, data warehouses, and AI tools." tags: ["Marketing automation"] updated: 2026-11-05T07:17:25Z published: 2026-11-05T07:17:25Z canonical: "docs.supermetrics.com/hubspot-contacts-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # HubSpot Contacts connection guide This guide contains all permissions and requirements for connecting your HubSpot Contacts data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/hubspot-contacts-connection-guide#connection-instructions). ## Required permissions ### User permissions You must have sufficient permissions in HubSpot to install and authorize the app. One of the following roles is required: - Admin - Owner (full access) [Learn more about user roles in HubSpot's documentation](https://knowledge.hubspot.com/settings/hubspot-user-permissions-guide#account-access). ### Supported products To use the HubSpot Contacts data source, you need one of the following HubSpot products or higher: - Marketing Hub - Free - Sales Hub - Free - Service Hub - Free - Content Hub - Free - Data Hub - Free ## Connection instructions When connecting to HubSpot Contacts, you need to log in to HubSpot and select the portal to use when prompted. 1. Select the HubSpot Contacts data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Log in with your HubSpot details once prompted. If you're currently logged into a HubSpot account, Supermetrics will use those credentials to authenticate your connection. 5. Choose which portal to authorize with. 6. Click **Allow** to allow the Supermetrics app to access your data. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to HubSpot Contacts from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) ## More resources - [HubSpot Contacts metrics and dimensions](/v1/docs/hubspot-contacts-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
