--- title: "HubSpot connection guide" slug: "hubspot-connection-guide" description: "Connect your HubSpot data to Supermetrics with our guide on permissions and connection steps for seamless data integration." updated: 2026-09-07T07:47:39Z published: 2026-09-07T07:47:39Z canonical: "docs.supermetrics.com/hubspot-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # HubSpot connection guide This guide contains all permissions and requirements for connecting your HubSpot data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/hubspot-connection-guide#connection-instructions). ## Required permissions To connect, you'll need a HubSpot account with either of these user roles: - Admin - Super Admin or Owner (full access) [Learn more about user roles in HubSpot's documentation.](https://knowledge.hubspot.com/settings/hubspot-user-permissions-guide#account-access) ## Connection instructions When connecting to HubSpot, you need to log in to HubSpot. 1. Select the HubSpot data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Log in to HubSpot. 5. Select an account and click **Choose account**. 6. Select the scopes and click **Connect app**. ![Connecting Supermetrics to HubSpot, detailing required and optional access permissions.](https://cdn.document360.io/a13cead5-eaae-456f-9bd1-0941d590c0e3/Images/Documentation/HubSpot_OAuth-2.png) 7. In your data destination, select the accounts to include in your reporting. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to HubSpot from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [HubSpot report building guide](/v1/docs/hubspot-report-building-guide) - [HubSpot: Permissions troubleshooting guide](/v1/docs/hubspot-permissions-troubleshooting-guide) - [How to monitor your HubSpot import status](/v1/docs/how-to-monitor-your-hubspot-data-import-status) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
