--- title: "How to switch from custom Supermetrics connector to certified connector in Power BI" slug: "how-to-switch-from-custom-supermetrics-connector-to-certified-connector-in-power-bi" description: "Learn how to switch from custom Supermetrics connector to certified connector in Power BI." updated: 2025-06-26T15:25:58Z published: 2025-06-26T15:25:58Z canonical: "docs.supermetrics.com/how-to-switch-from-custom-supermetrics-connector-to-certified-connector-in-power-bi" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to switch from custom Supermetrics connector to certified connector in Power BI The Supermetrics connector for Power BI has been certified by Microsoft and comes with Power BI Desktop starting from version 2.128.751.0 (April 2024 update). If you've previously used the custom Supermetrics connector that you installed manually, we recommend removing the connector and switching to the certified version, as it supports scheduled refreshes and other native Power BI features. ## Instructions 1. Launch Power BI Desktop. 2. Open the **Help** tab on the top menu. 3. Click **About** to check the version of Power BI Desktop that you're currently using. The Supermetrics connector is available starting from version 2.128.751.0 (April 2024 update). 4. If you have an outdated version of Power BI Desktop, download the latest version from the [Microsoft Download Center](https://www.microsoft.com/download/details.aspx?id=58494). Windows 10 users can also download the latest version of Power BI Desktop from the [Microsoft Store](https://aka.ms/pbidesktopstore). 5. Find the folder `[Documents]\Power BI Desktop\Custom Connectors` on your computer and delete the `Supermetrics.mez` or` Supermetrics.pqx` file in the folder. If you're not using other custom connectors, you can delete the entire folder. 6. Open Power BI Desktop. 7. Click **Get Data** → **More**. 8. Make sure that you can find the Supermetrics connector in the list. If you were using an on-premises gateway for scheduled updates, see our [instructions for switching to the native Power BI refresh functionality](/v1/docs/how-to-set-up-scheduled-refreshes-in-power-bi).
