title: "How to reauthenticate a data source connection in Google Sheets, Data Studio, Excel, Power BI, and Supermetrics Hub"
slug: "how-to-reauthenticate-a-data-source-connection-in-google-sheets-looker-studio-excel-power-bi-and-supermetrics-hub"
description: "Reauthenticate your data source connection easily with these step-by-step instructions for Google Sheets, Data Studio, Excel, and Power BI."
updated: 2026-05-06T13:20:47Z
published: 2026-05-06T13:20:47Z
> ## Documentation Index
# How to reauthenticate a data source connection in Google Sheets, Data Studio, Excel, Power BI, and Supermetrics Hub
Sometimes, your connection to a data source times out, or your connection needs to be renewed for another reason.
Reauthenticating can solve these errors, among others:
- `Error: Invalid credentials`
- `Authentication failed`
Follow these steps to reauthenticate the data source connection.
## Instructions
You can renew the connection to your data source on the Supermetrics Hub. The connection will also be updated in the destinations you're using.
1. [Go to the Data sources page on the Hub](https://hub.supermetrics.com/token-management).
2. Click the data source you need to authenticate and find the connection to reauthenticate.
3. Click the reconnect icon (![Circular arrows indicating a refresh action in a user interface element.](https://cdn.document360.io/a13cead5-eaae-456f-9bd1-0941d590c0e3/Images/Documentation/hub-refresh-icon.png)) at the end of the row.
4. [Follow the data source-specific instructions to connect to the data source](/v1/docs/connect).
Take a look at [this support article for more instructions on how to manage data source connections on the Hub](/v1/docs/how-to-manage-data-source-connections-on-supermetrics-hub).
You can also reconnect to your data source from your data destination. Follow the instructions below.
****Google Sheets****
[Embedded content](https://www.youtube.com/embed/-eRafMECL54)
1. [Open a Google Sheets file](https://docs.google.com/spreadsheets/u/0/).
2. Click **Extensions → Supermetrics → Launch** to open the sidebar.
3. Go to the **Queries** tab.
4. Select a query that uses the data source you want to reauthenticate from the sidebar. Click the **3-dot menu**next to its name.
5. Click **Manage data source connection**.
6. In the data source list, click the **chevron** (![A downward arrow indicating a dropdown menu for user interaction.](https://cdn.document360.io/a13cead5-eaae-456f-9bd1-0941d590c0e3/Images/Documentation/hub-chevron-icon.png)) next to the data source's name.
7. Click **+ Add connection.**
8. [Connect to the data source again.](/v1/docs/connect)
Updating one query will refresh all queries using the same token.
If you're using an older version of the Supermetrics sidebar, skip step 3. Instead, just select the data source from the sidebar and then follow steps 6 through 8.
**Troubleshooting**
- If your account still doesn't appear on the account list, reauthenticate again in an incognito window.
- If you encounter one of the Google errors below, [follow these instructions to resolve Google Account issues](/v1/docs/how-to-fix-login-errors-across-multiple-google-accounts).
  - `This action is not supported when you are logged with multiple accounts `
  - `This was a reauthorization request for user A but you logged in as user B`
- If you encounter an error that reads `No accounts selected`,**it means you haven't selected any accounts when authenticating the data source.
  - To fix this, open the data source settings by selecting the data source in the sidebar in Google Sheets, and select at least one account under **Select accounts**. Note that this option sometimes uses a different name — if you're using Google Analytics 4, for example, it'll read **Select properties**.
****Data Studio (formerly Looker Studio)****
[Embedded content](https://www.youtube.com/embed/L1YlvIuHJfo?&amp;wmode=opaque)
1. [Open Data Studio.](https://datastudio.google.com/navigation/datasources) Click on the **data source** you'd like to reauthenticate. If you're actively editing a report, click the **Edit icon** (![A pencil icon representing editing functionality in a digital interface.](https://cdn.document360.io/a13cead5-eaae-456f-9bd1-0941d590c0e3/Images/Documentation/ls-edit-icon.png)) next to your data source (or click **Resource → Managed added data sources** and click **Edit** there).
2. On the left side, click **Edit connection**.
3. In the data source settings, click the link after **View & manage your connections**.
4. Choose the team that the connection you'd like to authenticate belongs to.
5. Click the 3-dot menu and select **Reconnect**.
6. [Connect to the data source again](/v1/docs/connect).
7. Click **Complete and continue** and **Close this window** to return to Data Studio.
8. In Data Studio, click **Reconnect**.
9. Click **Apply** to apply the connection changes.
10. Click **Done**.
**Remove a data source from Data Studio**
1. Navigate to **Resource → Manage added data sources**.
2. Find the data source in the list that you want to remove and click **Remove**.
3. Click **Remove data source** to confirm.
**Revoke a data source in Data Studio**
1. On the top sidebar, click **Add data.**
2. Find the data source’s name with "by Supermetrics" beneath it.
3. Click the **3-dot menu**on the card to open the options menu.
4. Click **Revoke access**.
5. Click **Remove** to proceed.
6. Click **Remove anyway** to confirm.
**Troubleshooting**
- If you encounter an error that read `No accounts selected`,**it means you haven't selected any accounts when authenticating the data source.
  - To fix this, open the data source settings by selecting the data source and clicking the edit icon, and select at least one account under **Select accounts**. Note that this option sometimes uses a different name — if you're using Google Analytics 4, for example, it'll read **Select properties**.
![Interface section for selecting accounts with an option to modify reports.](https://cdn.document360.io/a13cead5-eaae-456f-9bd1-0941d590c0e3/Images/Documentation/ls-select-accounts.png)
****Excel****
1. [Open an Excel file](https://www.office.com/launch/excel?ui=en-US&amp;rs=GB&amp;auth=1).
2. Click **Data** → **Show Supermetrics.**If you're actively editing an existing query, navigate to **Query → Stop modifying**.
3. Open the **Data source** section.
4. Navigate to the data source. Click the chevron next to the data source's name.
5. Click **Add connection**.
**Troubleshooting**
  - To fix this, open the data source settings by selecting the data source in the sidebar in Excel, and select at least one account under **Select accounts**. Note that this option sometimes uses a different name — if you're using Google Analytics 4, for example, it'll read **Select properties**.
****Power BI****
1. Go to [Power BI on the Supermetrics Hub](https://hub.supermetrics.com/power-bi).
2. In the list of queries, click the data source you'd like to reauthenticate.
3. Click the query to see its details, and click the pencil icon on the right to edit the query.
4. Navigate to the query connection details.
5. Click the trash can icon next to the connection to remove the old connection.
6. Click **New connection**.
7. [Follow the steps in our data source connection guides to reconnect](/v1/docs/connect).
## Troubleshooting
If you get stuck in an authentication loop, log out from the data source platform completely to clear any bad sessions and cookies. Then, you can start the authentication process again.
