title: "How to load your data to Power BI"
slug: "how-to-load-your-data-to-power-bi"
description: "Connect Supermetrics to Power BI easily. Follow our step-by-step guide to import your data and enhance your reports with saved queries."
updated: 2025-06-26T15:20:25Z
published: 2025-06-26T15:20:25Z
> ## Documentation Index
# How to load your data to Power BI
Once you’ve [connected to your data source and saved your query](/v1/docs/how-to-create-your-first-supermetrics-query-for-power-bi), it's time to get your data in Power BI.
## Instructions
1. Open Power BI Desktop.
2. In the **Home** ribbon, click **Get Data**.
3. Search and select Supermetrics, and click **Connect**.
You can find Supermetrics as a connector in [Power BI Desktop](https://www.microsoft.com/en-us/download/details.aspx?id=58494) versions starting from 2.128.751.0 (April 2024 update). [Check these instructions if you can't find the Supermetrics connector](/v1/docs/how-to-find-the-supermetrics-custom-connector-in-power-bi).
4. If you're connecting to Supermetrics for the first time, you'll see a third-party notice. Select **Don't warn me again with this connector** if you don't want this message to be displayed again, and click **Continue**.
5. Click **Sign in** to log in to your Supermetrics account.
6. Use single sign-on (SSO) in the Supermetrics window that appears: click **Sign in with Microsoft** or **Sign in with Google** and choose the same account that you use (or plan to use) to sign in to the Supermetrics Hub.
7. If you're a member of more than one Supermetrics team, select a team.
8. Once you've signed in, click **Continue**.
9. Click **Connect**.Once the Navigator dialog box loads, you'll be able to preview all queries you've saved in your Supermetrics account on the Hub. They're organized by the data source in the folders on the left.
10. Select the checkboxes next to any queries with data you'd like to use for your report.
11. [You can modify the account, date range, or metrics used for the current report](/v1/docs/how-to-customize-data-loaded-to-your-power-bi-report). Select the option above the preview and click **Apply**. Make sure you always use accounts from one connection.
## Next steps
- [Set up scheduled refreshes in Power BI](/v1/docs/how-to-set-up-scheduled-refreshes-in-power-bi)
- [Customize data loaded to your Power BI report](/v1/docs/how-to-customize-data-loaded-to-your-power-bi-report)
