--- title: "How to load data from Supermetrics Storage to Power BI" slug: "how-to-load-data-from-supermetrics-storage-to-power-bi" description: "Learn how to load your data from Supermetrics Storage to Power BI for easy report building." updated: 2025-06-26T12:30:43Z published: 2025-06-26T12:30:43Z canonical: "docs.supermetrics.com/how-to-load-data-from-supermetrics-storage-to-power-bi" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to load data from Supermetrics Storage to Power BI Follow this guide to load your data from your Supermetrics Storage to your Power BI instance. ## Instructions ### Step 1: Create a transfer to your Supermetrics Storage 1. Create a transfer to your Supermetrics Storage. See the instructions on [how to create a transfer](/v1/docs/how-to-create-a-transfer). 2. Confirm that the transfer was successful and that your Storage has data. ### Step 2: Load the data to your Power BI instance 1. In Power BI, click **Get data** in the ribbon. 2. Search for **GoogleBigQuery**. 3. Click **OK**. 4. Sign in to your Google Account. 5. Click **Allow** to allow Power BI to access your Google Account. Close the window and return to the Power BI instance. 6. Click **Connect**. 7. In Navigator, select the table groups to load to Power BI, and click **Load**. 8. In the **Connection settings** window, make sure that Import is selected, and click **OK**. 9. Once the data has been loaded to Power BI, you can see the table groups in the **Data** sidebar.
