--- title: "How to fix permission errors" slug: "how-to-fix-permission-errors" description: "Fix Supermetrics permissions errors for data sources like Facebook Ads and LinkedIn. Follow our guide to troubleshoot login issues and access problems." updated: 2026-09-29T05:36:18Z published: 2026-09-29T05:36:18Z canonical: "docs.supermetrics.com/how-to-fix-permission-errors" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to fix permission errors The data source permissions define what data you can pull and also how your connection to the data source works. To keep data safe, Supermetrics notices if you don’t have sufficient permissions to pull the data. This guide will walk you through how to fix permissions errors when you’re logging into a data source with Supermetrics. These errors can include: - `It seems you tried to log in with a user that does not have (data source) enabled. Please try again with another user account.` - `Please login with a data source user that has access to at least one account.` - `We did not find any accounts with your login credentials. Please try again using a different login.` - `Invalid credentials/Invalid credentials provided.` - `User is not authorized to make this request.` - `This user does not have permission to read data.` - `User permission denied: user doesn’t have permissions for account.` - `Failed to authenticate with the provided information.` - `You do not have access to get data from page ID ` These steps also solve permissions errors specific to only one data source. These include: - **Facebook Ads and Instagram Insights**: `Unsupported get request and Fetching insights caused the following error: (#10) Application does not have permission for this action.` - **X Ads (Twitter)**: `This user does not have permission to read campaign data and User is not authorized to make this request.` - **LinkedIn Company Pages**:` The request requires higher privileges than provided by the access token.` ## Instructions ### Check permissions Check from the [connection guide for each data source](/v1/docs/connect) what permissions are required for each data source, and that you have sufficient role and permissions to pull data. If you can’t change your access or permission level, contact your account administrator. ### Troubleshooting Try these checks if the error persists after you've adjusted permissions. - Reauthenticate your connection to the data source. Follow the steps in the [reauthentication guide](/v1/docs/how-to-reauthenticate-a-data-source-connection). - [Check that you are assigned as a user to your subscription](/v1/docs/about-supermetrics-teams-and-user-roles). - [Check that the data source is supported by your subscription package](https://supermetrics.com/pricing). [](/v1/docs/) If the problem persists with **Instagram** or **Facebook**, [reset your Facebook business integration](/v1/docs/how-to-reset-the-supermetrics-facebook-business-integrations).
