--- title: "How to fix a parameters error in Data Studio" slug: "how-to-fix-a-parameters-error-in-data-studio" description: "Learn how to fix parameters errors in Data Studio and make sure that your account is properly configured." updated: 2026-05-06T12:43:09Z published: 2026-05-06T13:19:08Z canonical: "docs.supermetrics.com/how-to-fix-a-parameters-error-in-data-studio" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to fix a parameters error in Data Studio The following error is caused by the account values in the parameter inside Data Studio (formerly Looker Studio) report that have been changed or are no longer valid. - `This data source was improperly configured. The parameters available in this report have changed and the current values are no longer valid.` Follow these steps if you see this error in Data Studio. ## Instructions ### Solution 1: Targeted fix This solution fixes the error by re-validating the account selection only in the specific chart that is failing. This is the recommended approach if your report utilizes different account selections across various charts. 1. Log in to Data Studio and open the impaced report. 2. Click the specific chart or element that’s displaying the error. 3. In the Data Studio configuration panel (usually on the right), scroll down to the **connector parameters** (where the accounts are selected). 4. In the dropdown menu selection, **deselect and immediately reselect the accounts required** for this specific chart. Even if the accounts appear correct, this action forces Data Studio to refresh the parameter value, solving the error. 5. The error should clear immediately for this chart. ### Solution 2: Global fix If Solution 1 does not resolve the issue, or if the error persists across multiple elements, you can apply this global fix. > [!NOTE] > Note > > This action involves toggling the data source configuration and will likely reset any custom account selections you have configured for individual charts or elements within this report. 1. Log in to Data Studio and open the impacted report. 2. Click any report element to open Supermetrics. 3. Navigate to **Data sources** in the Supermetrics pane. 4. Click the pencil icon next to the affected data source. 5. Click **Edit connection**. 6. Deselect the **Allow "Select accounts" to be modified in reports** checkbox. 7. Click **Reconnect**. 8. Click **Apply**. 9. Click **Done**. If you want to re-enable the **Allow "Select accounts" to be modified in reports** option, you can follow the steps above and select the checkbox. Note that re-enabling this option has a chance of introducing the same error the next time your account values have been changed or are no longer valid. You'll also see this error if you've set up multiple account selector controls from different data sources on the same Data Studio report page. To avoid the error, make sure that you use only one account selector control per page.
