--- title: "How to add images to Power BI reports" slug: "how-to-add-images-to-power-bi-reports" description: "Make your Power BI reports more vibrant by including the image assets from your data." updated: 2025-06-26T15:23:26Z published: 2025-06-26T15:23:26Z canonical: "docs.supermetrics.com/how-to-add-images-to-power-bi-reports" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to add images to Power BI reports To add images to your Power BI report, all you need to do is to include image URLs as a dimension in your query and change the data category to Image URL on the Power BI side. Note that the image URL must be directly accessible via a link without signing in on a specific resource, such as SharePoint. The following image formats are supported: - `bmp` - `jpg, jpeg` - `gif` - `png` - `svg` ## Instructions 1. When creating a query for Power BI, make sure you select a dimension with the image URLs. 2. Load the query data into Power BI. 3. Select the column that contains the image URLs under the **Data** tab. 4. Go to the **Column tools** menu in the **Power BI** ribbon. 5. Set the **Data category** to **Image URL**. See [Microsoft's instructions for more information about how to manage images in Power BI tables](https://learn.microsoft.com/en-us/power-bi/create-reports/power-bi-images-tables).
