--- title: "Gong connection guide" slug: "gong-connection-guide" description: "Connect your Gong data to Supermetrics effortlessly. Learn about permissions, API Access Keys, and query types for seamless data integration." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/gong-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Gong connection guide This guide contains all permissions and requirements for connecting your Gong data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/gong-connection-guide#connection-instructions). ## Before you begin Before using the Gong connector, you’ll need an **Access Key**, an **Access Key Secret**, and your **base URL**. ### How to find your base URL and create an API Access Key 1. Log in to your Gong account with a user who has at least **Technical Administrator** permissions. 2. Navigate to the Gong [API page](https://app.gong.io/company/api-authentication) in the Admin center. 3. The **Base URL** for all API calls will be visible in the top section of the page. Copy this URL for later use. 4. Click **Create** to generate new API credentials. 5. The **Access Key** and **Access Key Secret** will only be shown once. Copy these to a secure location for later use. ## Query types If prompted, you need to select a query type to pull data. - **Calls**: Retrieve detailed insights on your sales calls. ## Connection instructions 1. Select the Gong data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Gong **Base URL**, **Access Key**, **Access Key Secret**, and give a name for your login, “Supermetrics for example”. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the account to pull data from and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Gong from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
