--- title: "Glassdoor Reviews connection guide" slug: "glassdoor-reviews-connection-guide" description: "Connect your Glassdoor Reviews data to Supermetrics effortlessly. Learn about permissions, company IDs, and query types for seamless data integration." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/glassdoor-reviews-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Glassdoor Reviews connection guide This guide contains all permissions and requirements for connecting your Glassdoor Reviews data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/glassdoor-reviews-connection-guide#connection-instructions). ## Required permissions You can query publicly available company review data from Glassdoor Reviews without logging in to Glassdoor. To pull data on a company on Glassdoor, you'll need to copy the company's identifier — called its **company ID** — from its Glassdoor URL. For example, if a company's Glassdoor Reviews URL is` glassdoor.com/Reviews/Supermetrics-Reviews`-E**1234567**, its company ID is **1234567**. ## Query types If prompted, you need to select a query type to pull data. - **Reviews**: Fetch up to 1,000 of the latest public reviews for a company. ## Connection instructions When connecting to Glassdoor Reviews, you need to enter the company IDs to query. 1. Select the Glassdoor Reviews data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. In your data destination, enter the company ID and the language you'd like to pull reviews for. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Glassdoor Reviews from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
