--- title: "Eskimi connection guide" slug: "eskimi-connection-guide" description: "Connect your Eskimi data to Supermetrics with our guide. Learn about permissions, API credentials, and query types for seamless data integration." tags: ["Paid media"] updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/eskimi-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Eskimi connection guide This guide contains all permissions and requirements for connecting your Eskimi data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/eskimi-connection-guide#connection-instructions). ## Required permissions Before using the Eskimi connector, you need your Eskimi Username, password and Client ID, Client Secret and Advertiser ID of the advertiser you want to connect and fetch data for. ### How to obtain your API credentials 1. Log in to the [Eskimi DSP dashboard](https://dsp.eskimi.com/). 2. In the top right corner, click the **three dot icon** and select **API Clients**. 3. Click **Add Client**. 4. Enter a **Client Name**, the name is for reference only and does not affect the token. 5. Click **Generate** to create a **Client Secret** and click **Save**. 6. After refreshing the page, click **Generate Client Token**. 7. Enter your account password for verification, then click **Confirm Identity & Generate**. 8. Copy the generated **Client Token** to use for API requests. 9. Click **Save** to Finalize. ### How to obtain your Advertiser ID 1. Log in to your [Eskimi DSP dashboard](https://dsp.eskimi.com/). 2. Switch to the advertiser account you want to connect. 3. Go to [Campaigns](https://dsp.eskimi.com/admin/campaigns). 4. Find your advertiser ID in the URL as `admin_id`, for example: `?admin_id=2100`. ## Query types If prompted, you need to select a query type to pull data. - **Campaign performance**: Pull all the dimensions and performance metrics for your DSP campaigns. ## Connection instructions 1. Select the Eskimi data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter the API credentials, your advertiser ID, your username and password, and give a name for your login. 3. If prompted, choose to make this connection [shared or private](https://docs.supermetrics.com/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the advertisers to include in your reporting and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Eskimi from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
