--- title: "Eloqua connection guide" slug: "eloqua-connection-guide" description: "Connect Eloqua to Supermetrics with our guide on permissions, authentication methods, and connection instructions." tags: ["Marketing automation"] updated: 2026-11-04T14:13:29Z published: 2026-11-04T14:13:29Z canonical: "docs.supermetrics.com/eloqua-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Eloqua connection guide This guide contains all permissions and requirements for connecting your Eloqua data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/eloqua-connection-guide#connection-instructions). ## Required permissions You will need your Eloqua **username**, **password**, and **site name** to connect to Eloqua. The site name can be found in your Eloqua account by clicking on the top right account box and then copying the site name underneath your account name. ## Query types Query types define which metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Campaign analysis**: Retrieve insights on your Eloqua campaigns. - **Campaign form submissions**: Retrieve insights on your Eloqua form submissions on a campaign level. ## Connection instructions When connecting to Eloqua, you need to enter your username, password, and site name. 1. Select the Eloqua data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Eloqua **username**, **password**, and **site name**. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the account to pull data from and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Eloqua from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - Supermetrics APIs: [How to get started with the Supermetrics APIs](/v1-api/apidocs/get-started-with-supermetrics-api) — You can also [create Data API query URLs in Data Explorer](/v1/docs/how-to-use-data-explorer). - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Eloqua metrics and dimensions](/v1/docs/eloqua-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
