--- title: "Database connection guide" slug: "database-connection-guide" description: "Connect your SQL database to Supermetrics in Google Sheets, transform data, and enhance your reports with custom insights. Get started today!" updated: 2025-07-14T15:06:31Z published: 2025-07-14T15:06:31Z canonical: "docs.supermetrics.com/database-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Database connection guide Use this guide to connect your SQL database to Supermetrics, and seamlessly add its data to your reports. The database connector is only available in Google Sheets. Use the database connector to connect to a data source Supermetrics doesn't support at the moment, and also for custom in-house data. Then, transform or combine data before adding it to your reports. **Tables** that contain all data in the database and **Views** that contain the results of a query in a virtual table are supported. SSH connections and write-specific SQL functions are not supported for the SQL database connector. Supported database types: - MySQL - Oracle - MariaDB - PostgreSQL - Microsoft SQL Server - Amazon Redshift - Google Cloud SQL for MySQL - Microsoft Azure SQL ## Before you begin Check the access requirements with your database administrator before using the database connector. ### Database connector configuration Before connecting, make sure you have the following information available: - **DB type** – The database type or technology being used - **DB address** – IP or URL to the SQL server - **DB port** – Port number the server is expecting connections through - **Database name** – Name of the data based to connect to - **Username** – Account that has permissions to access the database - **Password** – Password for the account - **Use SSL** – Setting that allows SSL to be used, if the server connection requires it. ### IP allowlisting To use Supermetrics with your database, your database needs to accept connections from specific IP addresses. See the [list of IP addresses to allowlist](/v1/docs/about-ip-address-allowlisting). > [!NOTE] > Note > > If the IP addresses listed in the article don't work and you get an `Access denied` error, try the Google IP addresses listed below. For example, AWS accepts a comma-separated list. ****Google IP addresses**** - 8.8.4.0/24 - 8.8.8.0/24 - 8.35.200.0/21 - 34.0.0.0/15 - 34.2.0.0/16 - 34.3.0.0/23 - 34.3.3.0/24 - 34.3.4.0/24 - 34.3.8.0/21 - 34.3.16.0/20 - 34.3.32.0/19 - 34.3.64.0/18 - 34.3.128.0/17 - 34.4.0.0/14 - 34.8.0.0/13 - 34.17.0.0/16 - 34.18.0.0/16 - 34.22.64.0/18 - 34.22.128.0/17 - 34.31.0.0/16 - 34.32.0.0/11 - 34.64.0.0/19 - 34.96.0.0/18 - 34.98.0.0/18 - 34.98.136.0/21 - 34.98.144.0/20 - 34.98.160.0/19 - 34.98.192.0/18 - 34.99.0.0/16 - 34.100.0.0/17 - 34.101.0.0/20 - 34.101.16.0/23 - 34.101.19.0/24 - 34.101.28.0/22 - 34.103.0.0/16 - 34.104.0.0/20 - 34.104.16.0/21 - 34.104.24.0/23 - 34.104.26.0/24 - 34.104.28.0/22 - 34.104.32.0/20 - 34.104.48.0/24 - 34.104.53.0/24 - 34.104.54.0/23 - 34.109.0.0/16 - 34.110.0.0/17 - 34.112.0.0/14 - 34.116.8.0/21 - 34.116.16.0/20 - 34.116.32.0/19 - 34.118.208.0/20 - 34.118.224.0/20 - 34.119.0.0/16 - 34.124.64.0/19 - 34.124.96.0/20 - 34.126.0.0/18 - 34.126.224.0/19 - 34.127.128.0/19 - 34.127.160.0/20 - 34.127.176.0/24 - 34.127.181.0/24 - 34.127.182.0/23 - 34.127.192.0/18 - 34.128.0.0/18 - 34.128.192.0/18 - 34.140.128.0/24 - 34.143.0.0/17 - 34.144.0.0/17 - 34.144.128.0/18 - 34.152.64.0/18 - 34.152.128.0/17 - 34.153.0.0/16 - 34.156.0.0/16 - 34.157.10.0/23 - 34.157.86.0/24 - 34.157.120.0/21 - 34.157.138.0/23 - 34.157.214.0/24 - 34.157.218.0/23 - 34.157.248.0/21 - 34.158.0.0/16 - 34.166.0.0/15 - 34.177.0.0/16 - 34.178.0.0/15 - 34.180.0.0/14 - 34.184.0.0/13 - 35.187.128.0/20 - 35.190.96.0/20 - 35.190.240.0/20 - 35.191.0.0/16 - 35.199.128.0/20 - 35.201.32.0/21 - 35.201.40.0/24 - 35.201.42.0/23 - 35.201.44.0/22 - 35.201.48.0/20 - 35.203.192.0/20 - 35.203.208.0/23 - 35.203.220.0/22 - 35.203.224.0/21 - 35.203.240.0/20 - 35.206.0.0/21 - 35.206.8.0/23 - 35.206.12.0/22 - 35.206.16.0/20 - 35.218.0.0/16 - 35.219.192.0/19 - 35.220.28.0/23 - 35.220.30.0/24 - 35.229.0.0/20 - 35.230.192.0/19 - 35.230.224.0/20 - 35.235.128.0/18 - 35.235.192.0/20 - 35.235.208.0/21 - 35.235.224.0/19 - 35.242.28.0/23 - 35.242.30.0/24 - 35.243.16.0/20 - 35.243.48.0/21 - 64.15.112.0/20 - 64.18.0.0/20 - 64.233.160.0/19 - 66.22.228.0/23 - 66.102.0.0/20 - 66.249.64.0/19 - 70.32.128.0/19 - 72.14.192.0/18 - 74.114.24.0/21 - 74.125.0.0/16 - 104.154.0.0/20 - 104.154.112.0/24 - 104.154.122.0/23 - 104.154.124.0/22 - 104.155.240.0/20 - 104.196.64.0/24 - 104.196.72.0/21 - 104.196.80.0/20 - 104.199.64.0/23 - 104.199.240.0/23 - 104.237.160.0/19 - 107.178.192.0/20 - 107.178.224.0/20 - 108.170.192.0/18 - 108.177.0.0/17 - 130.211.0.0/22 - 136.112.0.0/12 - 142.250.0.0/15 - 146.148.0.0/23 - 172.110.32.0/21 - 172.217.0.0/16 - 172.253.0.0/16 - 173.194.0.0/16 - 192.178.0.0/15 - 193.186.4.0/24 - 199.36.154.0/23 - 199.36.156.0/24 - 199.192.112.0/23 - 199.192.114.0/24 - 199.223.237.0/24 - 199.223.238.0/23 - 207.126.144.0/24 - 207.223.160.0/20 - 208.65.152.0/22 - 208.68.108.0/22 - 208.81.188.0/22 - 208.117.224.0/19 - 209.85.128.0/17 - 216.58.192.0/19 - 216.73.80.0/20 - 216.239.32.0/19 ## Instructions Make sure you've [installed the Supermetrics add-on](/v1/docs/how-to-install-supermetrics-in-google-sheets) before you connect. 1. [Open a new Google Sheets file](https://docs.google.com/spreadsheets/u/0/). 2. Navigate to **Extensions → Supermetrics → Launch sidebar** to open Supermetrics. 3. Click **Create new query**. 4. Under **Data source**, select **Database**. 5. Fill in the information for your connection. See [database connector configuration](/v1/docs/database-connection-guide#database-connector-configuration) above for more details. 6. Click **Test connection** to verify the configuration. 7. Click **Save**. 8. Write your SQL statement in the Query SQL box. 9. Click **Get data** to pull your data. ## More resources - Learn about [advanced settings, best practices, and troubleshooting tips](/v1/docs/google-sheets) for Supermetrics for Google Sheets. - Learn how to use the ["Combine new results with old" setting in Google Sheets](/v1/docs/how-to-use-the-combine-new-results-with-old-setting-in-google-sheets).
