--- title: "CJ Affiliate (Commission Junction) connection guide" slug: "cj-affiliate-commission-junction-connection-guide" description: "Connect your CJ Affiliate data to Supermetrics with our guide. Learn about permissions, access tokens, and query types for seamless integration." updated: 2026-10-08T05:25:24Z published: 2026-10-08T05:25:24Z canonical: "docs.supermetrics.com/cj-affiliate-commission-junction-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # CJ Affiliate (Commission Junction) connection guide This guide contains all permissions and requirements for connecting your CJ Affiliate (Commission Junction) data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/cj-affiliate-commission-junction-connection-guide#connection-instructions). ## Required permissions To connect from Supermetrics to your CJ Affiliate (Commission Junction) account, you need a personal access token and your company ID (CID). - The personal access token is generated either by your admin or yourself at [CJ Affiliate's developer portal](https://developers.cj.com/account/personal-access-tokens). - You can see your company ID (CID) by clicking on your company name in the upper right corner of the [CJ Affiliate platform](https://members.cj.com/). The CID number is shown under the CID column. Note that only Advertiser accounts are supported. ## Query types If prompted, you need to select a query type to pull data. - **Commission detail report**: Fetch nearly real-time commission data from your CJ Affiliate Advertiser accounts. ## Connection instructions When connecting to CJ Affiliate, you need to insert your CJ Affiliate credentials. 1. Select the CJ Affiliate data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert the personal access token and your company ID (CID), and give a name for your login. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the login you just named and, if prompted, select a query type. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to CJ Affiliate from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
