--- title: "Brevo connection guide" slug: "brevo-connection-guide" description: "Connect your Brevo data to Supermetrics with our guide on API keys, permissions, and handling IP address issues for seamless data integration." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/brevo-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Brevo connection guide This guide contains all permissions and requirements for connecting your Brevo data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/brevo-connection-guide#connection-instructions). ## Required permissions To connect Brevo to Supermetrics, you need an API key. Remember to keep this safe once you have it. ### Create an API key 1. [Log in to Brevo](https://account-app.brevo.com/account/login). 2. Click your account's name in the top right corner. 3. Select **SMTP & API**. 4. Go to the **API keys** tab. 5. Click **Create a new API key**. 6. Enter a name for your API key (for example, “Supermetrics”). 7. Click **Generate**. 8. Copy the API key from the list under "Your API keys". [Learn more about API keys in Brevo's documentation](https://developers.brevo.com/docs/getting-started). ## Query types If prompted, you need to select a query type to pull data. - **Email campaigns**: Pulls the most popular performance metrics for email campaigns ## Connection instructions When connecting to Brevo, you need to provide your API key. 1. Select the Brevo data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your API key. 3. Give your login a name to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Brevo from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## Brevo errors due to unauthorized IP addresses Brevo's API requires API calls to come from pre-authorized IP addresses. Supermetrics, however, uses dynamic IP addresses that change regularly, leading to connection errors when Brevo blocks unrecognized IPs. You can select a suitable setting for handling unknown IP addresses in Brevo's settings: - **Automatic IP review and authorization**: Brevo automatically authorizes IP addresses used within the first 30 days of API key creation. After this period, new IPs will require manual review. If enabled before the 30-day period ends, existing IPs may be blocked unless manually added to the authorized list. - **Manual IP authorization**: Manually review and approve each unknown IP before allowing API calls. - **No IP review**: Allow all unknown IP addresses to make API calls without any review. [Learn more about the IP address authorization methods from Brevo's documentation](https://help.brevo.com/hc/en-us/articles/5740111683858-Authorize-IP-addresses-for-API-calls-to-improve-security#h_01JHJRY73NSJ073T7BFS3WYXF3) and follow Brevo's instructions for setting up IP address handling that works for you. ## More resources - [About API rate limits in Brevo](/v1/docs/about-api-rate-limits-in-brevo) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
