--- title: "Braze connection guide" slug: "braze-connection-guide" description: "Connect your Braze data to Supermetrics with our guide on permissions, API keys, and query types for seamless data integration and analysis." tags: ["Marketing automation"] updated: 2026-11-04T14:09:08Z published: 2026-11-04T14:09:08Z canonical: "docs.supermetrics.com/braze-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Braze connection guide This guide contains all permissions and requirements for connecting your Braze data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/braze-connection-guide#connection-instructions). ## Required permissions You need a Braze REST API key and your Braze REST endpoint to connect to Braze. - **REST API key**: Created in Braze under **Settings** → **APIs and Identifiers** → **REST API Keys**. The key must have the following permissions: - `campaigns.list` - `campaigns.details` - `campaigns.data_series` Creating an API key requires the appropriate admin permissions in your Braze account. - **REST endpoint**: The REST API URL for your Braze instance, for example, `https://rest.iad-03.braze.com`. The REST API URL corresponds to your Braze dashboard cluster. You select it from a list when connecting. If you're unsure which endpoint to use, see [Braze's REST API endpoints](https://www.braze.com/docs/api/basics/#endpoints) (it matches the dashboard URL you log in to). ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data. - **Campaign performance**: message delivery and engagement metrics (sent, delivered, opens, clicks, bounces, and more) broken down by channel and message variation, per day. - **Campaign analytics**: campaign-level outcomes (revenue, conversions, and unique recipients), per day. ## Connection instructions When connecting to Braze, you enter your Braze REST API key and select your REST endpoint when prompted. Braze uses credential-based authentication, so there's no separate login window. 1. Select the Braze data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert your Braze REST API key and select your REST endpoint. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Braze from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Braze metrics and dimensions](/v1/docs/braze-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
