--- title: "Branch connection guide" slug: "branch-connection-guide" description: "Connect your Branch data to Supermetrics with our guide. Learn about permissions, query types, and connection instructions for seamless data integration." tags: ["Marketing attribution", "Mobile", "Analytics"] updated: 2026-11-04T14:08:50Z published: 2026-11-04T14:08:50Z canonical: "docs.supermetrics.com/branch-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Branch connection guide This guide contains all permissions and requirements for connecting your Branch data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/branch-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Branch account, you'll need a Branch key and secret. Get the key and key secret from **Branch Dashboard → Account Settings → Profile**. To access the Query API, you need to have both Aggregate Data and Export access. [Learn more about the Query API in Branch help](https://help.branch.io/developers-hub/reference/query-api). ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Summary (total)**: Get the raw organic data for app analytics from the Branch summary dashboard. - **Summary (unique)**: Get the unique data for app analytics from the Branch summary dashboard. [Learn more about the Branch dashboard and the relevant query types and filters to use with Supermetrics](/v1/docs/about-api-rate-limits-and-discrepancies-in-branch). ## Connection instructions When connecting to Branch, you need to provide your Branch key and secret. 1. Select the Branch data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Branch key and secret. 3. Give your login a name to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Branch from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Branch metrics and dimensions](/v1/docs/branch-fields) - [About API rate limits and discrepancies in Branch](/v1/docs/about-api-rate-limits-and-discrepancies-in-branch) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
