--- title: "Bluesky Public Data: Supermetrics connection guide" slug: "bluesky-public-data-connection-guide" description: "Connect your Bluesky data to Supermetrics effortlessly. Access user profiles, posts, and followers with our comprehensive guide and connection instructions." tags: ["Social media"] updated: 2026-11-04T14:08:26Z published: 2026-11-04T14:08:26Z canonical: "docs.supermetrics.com/bluesky-public-data-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Bluesky Public Data connection guide This guide contains all permissions and requirements for connecting your Bluesky data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/bluesky-public-data-connection-guide#connection-instructions). ## Required permissions The Bluesky Public Data connector connects directly to the public AT Protocol API (`api.bsky.app`) without needing any authentication or special access permissions. ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data. - **User profile:** Provides the current status of a profile (no date range needed). Requires one Bluesky handle. - **User posts:** Retrieves an author feed (including reposts) alongside engagement metrics over a specified date range. Requires one Bluesky handle. - **Followers:** Retrieves the active list of followers (no date range needed). Requires one Bluesky handle. - **Following:** Retrieves the active list of accounts being followed (no date range needed). Requires one Bluesky handle. ## Connection instructions When connecting to Bluesky Public Data, enter the target Bluesky handle using either the `username.bsky.social` or `username` format. 1. Select the Bluesky Public Data data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. In your data destination, select a query type, if prompted, and enter the Bluesky handle to include in your reporting. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Bluesky Public Data from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Bluesky Public Data metrics and dimensions](/v1/docs/bluesky-public-data-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
