--- title: "Base script configuration reference" slug: "base-script-configuration-reference" description: "Configure Supermetrics Data Activation commands to manage environments, page structures, and tag properties for efficient tag loading on your website." updated: 2026-06-02T11:16:37Z published: 2026-06-02T11:16:37Z canonical: "docs.supermetrics.com/base-script-configuration-reference" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Base script configuration reference This reference covers the configuration commands available in the Supermetrics Data Activation base script. Use these commands to set environments, define page structures, attach properties to tags, and control when tags load. For an introduction to the basescript and how to add it to your website, see About the basescript. ## Environment ### setEnvironment Select the environment for tag loading. Defaults to prod. ```javascript _st('setEnvironment', 'test'); ``` Use `test` to load tags from the test environment during development. Switch to prod (or omit the command entirely) for production. ## Page structure ### setPageStructure Identify the current page. Components form a tree structure that you use to organize tags. ```javascript _st('setPageStructure', 'category', 'subcategory'); ``` You can pass the structure as separate arguments or as a pipe-separated string: ```javascript _st('setPageStructure', 'category|subcategory'); ``` Both formats produce the same result. ### setDefaultPageStructure Set a fallback page structure. The basescript uses this structure when no setPageStructure command runs on a page. ```javascript _st('setDefaultPageStructure', 'default|structure'); ``` ### setStructurePrefix Add a prefix that the basescript prepends to the page structure. ```javascript _st('setStructurePrefix', 'special'); ``` If you set the prefix to special and the page structure to `category|subcategory`, the resulting structure becomes `special|category|subcategory`. ## Tag properties ### addTagProperty Add a single property to the current tag set. The property is forwarded to the remote system. ```javascript _st('addTagProperty', 'productId', '12345'); ``` ### addLocalTagProperty Add a single property to the current tag set. The property stays in the browser and isn't forwarded to the remote system. ```javascript _st('addLocalTagProperty', 'sessionStart', 'true'); ``` ### addTagProperties Add multiple properties to the current tag set at once. All properties are forwarded to the remote system. ```javascript _st('addTagProperties', {  productId: '12345',  category: 'electronics' }); ``` ### addLocalTagProperties Add multiple properties to the current tag set at once. All properties stay in the browser. ```javascript _st('addLocalTagProperties', {  viewCount: '3',  referrer: 'homepage' }); ``` ## Resetting and loading ### resetTags Reset the page structure and all previously configured properties. Use this before setting up a new page view — for example, in single-page applications when the user navigates without a full page reload. ```javascript _st('resetTags'); ``` ### loadTags Activate tag loading based on the settings you've configured. Call this after you've set the environment, page structure, and properties. **Standard call:** ```javascript _st('loadTags'); ``` **With page structure (shorthand):** ```javascript _st('loadTags', 'homepage', 'product'); ``` This is equivalent to calling setPageStructure followed by `loadTags`. **With page structure and properties (shorthand):** ```javascript _st('loadTags', 'homepage|product|details', { country: 'be', language: 'nl' }); ``` This sets the page structure and adds tag properties in a single call. ## Common patterns ### Standard page view A typical page with a defined structure and tag properties: ```javascript _st('setPageStructure', 'products', 'detail'); _st('addTagProperties', {  productId: '12345',  price: '49.99',  currency: 'EUR' }); _st('loadTags'); ``` ### Single-page application navigation When the user navigates in a single-page application, reset and reconfigure before loading tags: ```javascript _st('resetTags'); _st('setPageStructure', 'checkout', 'confirmation'); _st('addTagProperty', 'orderId', '98765'); _st('loadTags'); ``` ### Using the loadTags shorthand For simple pages where you only need a page structure and a few properties: ```javascript _st('loadTags', 'homepage', { campaign: 'spring-sale' }); ``` ## More resources - [How to set up web tracking and event collection](/v1/docs/how-to-set-up-web-tracking-and-event-collection)
