--- title: "Axon by AppLovin connection guide" slug: "axon-by-applovin-connection-guide" description: "Connect your Axon by AppLovin data to Supermetrics with our guide. Get your API key and learn to pull performance data for your campaigns easily." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/axon-by-applovin-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Axon by AppLovin connection guide This guide contains all permissions and requirements for connecting your Axon by AppLovin data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/axon-by-applovin-connection-guide#connection-instructions). ## Required permissions Before using the Axon by AppLovin connector, you need your API key from the AppLovin platform. To obtain the API key, navigate to the [Keys](https://dash.applovin.com/login#keys) tab of the account page in your AppLovin dashboard. #### How to generate an API Key 1. [Log in to Axon](https://dash.applovin.com/login) and go to the **API Keys tab** on your account page. 2. Click the **+ New API Key** button. 3. Give the API key a descriptive name to easily identify it, for example, “Supermetrics”. 4. Copy and securely store the new API key immediately. For security reasons, it will not be shown again. ## Query types If prompted, you need to select a query type to pull data. - **Performance**: Fetch performance data for your advertising campaigns. ## Connection instructions When connecting to Axon by AppLovin, you need your API key for the connection. 1. Select the Axon by AppLovin data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter the API key and give a name for your login. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the ad accounts to include in your reporting and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Axon (AppLovin) from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
