--- title: "Amplitude connection guide" slug: "amplitude-connection-guide" description: "Connect your Amplitude data to Supermetrics with our guide on permissions, API keys, and region selection for seamless data integration." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/amplitude-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Amplitude connection guide This guide contains all permissions and requirements for connecting your Amplitude data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/amplitude-connection-guide#connection-instructions). ## Required permissions You need an API key and secret key in order to connect to Amplitude. 1. Log in to the [Amplitude web interface](https://app.amplitude.com/login). 2. Click **Settings** in the top right corner and select **Organization settings**. 3. Click **Projects** in the left sidebar. 4. Select the project you wish to connect to. 5. Under **General**, click **Show** next to API Key and Secret Key. 6. Copy the API Key and Secret Key to a secure location. ### Region Amplitude projects are hosted either on Standard server or EU residency server. In order to identify where your project is hosted, open the [Amplitude web interface](https://app.amplitude.com/analytics/) and check the URL: - `app.amplitude.com` – Your project is hosted on Standard server. - `app.eu.amplitude.com` – Your project is hosted on an EU residency server. ## Query types If prompted, you need to select a query type to pull data. - **Events**: Fetch all events across a specified time range, including its values and event properties. ## Connection instructions When connecting to Amplitude, you need to provide your API key and secret key and select the region when prompted. 1. Select the Amplitude data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert the API key and secret key. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the region. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Amplitude from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
