--- title: "Adjust connection guide" slug: "adjust-connection-guide" description: "Connect your Adjust data to Supermetrics with our guide. Learn about API tokens, permissions, and query types for seamless data integration." updated: 2026-07-08T09:00:42Z published: 2026-07-08T09:00:42Z canonical: "docs.supermetrics.com/adjust-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Adjust connection guide This guide contains all permissions and requirements for connecting your Adjust data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/adjust-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Adjust, you'll need an API token to access your Adjust account. In Supermetrics, each Adjust app is considered an account, and you need to select the right Adjust app to use when querying data. ****Get your API token**** 1. Log in to Adjust and open your dashboard. 2. Click the menu in the top left corner to open the sidebar. 3. In the bottom left, click **My profile**. 4. In the right sidebar, click **API token**. 5. Copy the API token, and keep it secure. ## Query types If prompted, you need to select a query type to pull data. - Datascape ## Connection instructions When connecting to Adjust, you need to insert your API token and app key when prompted. 1. Select the Adjust data source on the Supermetrics Hub or in the data destination. 2. Enter your API token. 3. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](https://docs.supermetrics.com/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the query type to use, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Adjust from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
